(Topic ID: 231020)
Gottlieb System 3 Flipper issues
By JReedie
5 years ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by JReedie
    #1 5 years ago
    Please ignore my ignorance as I’m no System 3 expert but I’m working on a SF2 at the moment and it was having heaps of issues. Most of which I have now fixed however, currently all 3 flippers are dead, the flipper buttons are registering as I'm able to progress through the systems menu but when starting a game nothing happens. I’ve checked all fuses and they're fine, I’ve also checked all of the transistors on the driver board and they are fine too. The trough release coil is also refusing to fire so no balls are being put into play.
    The customer reported that last time the machine worked he could smell something burning so switched it off and thats when the flipper coils and also the trough release coil stopped working. The left upkicker coil was burnt out and I have ordered a replacement so I’m presuming thats what the burning smell was as theres no evidence anywhere else of anything thats toasted. Any ideas what else to look at regarding the flippers? I've read that the Q relay could potentially be the culprit but I want to gather as much information on as many possible causes as i can before turning up at the location to try and get the machine running again.
    #2 5 years ago
    Transistors won't effect the flippers (well, besides from the transistors that control the relays that enable the flippers...)
    Do you have voltage at the coils? F18,29,20,22 all have voltage on both sides? Tried grounding them?
    Do the slingshots work? Those are also enabled by the Q relay.
    #3 5 years ago
    zacaj i didnt actually have my multimeter on me, it was initially a call out for a simple fix, little did i know the horrors under the playfield. I asked the customer to test the slingshots for me and he has said they are not working either. Is it right to just assume the Q relay is the cause of the problems?
    #4 5 years ago
    Flippers, slingshots, and pop bumper only have one common point that I'm seeing on the schematic, and it's the Q relay+its connectors. I'd guess either the Q relay itself isn't working or the contacts are bad
    #5 5 years ago
    zacaj thanks for that, i’ll check out the Q relay on my next visit and hopefully thats the problem!
    #6 5 years ago
    Quick update, issue was the Q relay not firing. I've started a new thread as the problem has developed further
    https://pinside.com/pinball/forum/topic/gottlieb-system-3-troubles-1#post-4735683
    This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-system-3-flipper-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
