(Topic ID: 257647)
Gottlieb system 3 flipper issue
By broncoking
1 year ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by pinmike
#1 1 year ago
Hey everyone, im slowly restoring and working out some issues on my first pin. It's a gottlieb SMB. I've got the game working perfectly except for an issue with the right flipper. Im not really familiar with how the flipper systems work on these games so bear with me and I'm sorry if this is a rookie question. When I press the right button to activate the right flipper the coil fires normally, but if I press the right button and hold it to keep the flipper up the coil starts humming and getting hot. Both the left and upper flipper don't do this. Can someone point me in the right direction as to where to start looking? Upon visual inspection everything appears normal. No burn marks on the EOS or coil, the mechanical parts of the flipper function normally. Thanks guys.
#2 1 year ago
Also to add I'm noticing a blue arch happening at the flipper button as well as the EOS on the right flipper when the button is pressed.
#3 1 year ago
Quoted from broncoking:
It’s most likely the EOS switch on that right flipper.Just make sure the gap between eos blades are correctly adjusted
#4 1 year ago
Quoted from pinmike:
Ok , thanks. Is there a write up somewhere saying how to adjust them?
#5 1 year ago
PMed you Call me and I'll walk you through it
RussM
#6 1 year ago
The EOS switch is adjusted right, closed in the down position, open just as the flipper reaches the up position. The only think I could see wrong was whoever messed with it last did some pretty bad soldering on the coil lugs.
#7 1 year ago
Ok try and remove all that extra solder on the coil lugs and add the correct proper solder needed
#8 1 year ago
Alright, I got a new EOS on the way, the majority of the wires on the coil and EOS barely have any strands actually soldered on, the previous owner must not have been good with a soldering iron.
#9 1 year ago
Yes that’s most likely the case
