So I've recently done a full restoration on a Shaq Attaq (Yes, really I've spent countless hours restoring a shaq pinball ), I had changed playfields and it is now all put back together and the only problem I have left that I can't seem to fix is the bottom left flipper. Basically it won't work at all and blows the fuse immediately.
What I think could be the problem -
I put in new coils for the flippers and had originally wired this one incorrectly when I put a new one in. I have since put in another new coil and wired correctly but still get the same problem.
I have put LED's throughout the machine, I understand sometimes Sys 3's don't like this especially flashers, so I've put standard bulbs back in the flashers.
The diode's look fine, the flipper sensor board looks fine, EOS switch is set up fine and the flipper button works fine. So I don't know if it is something else up the daisy chain of the flipper switches is that's possible. Everything worked perfectly fine prior to the restorations and playfield swap apart from the flippers being very weak.
Any ideas of what the next thing I can do for troubleshooting would be much appreciated so I can finally post a thread about the restoration.
