I'm in the process of re-doing a Street Fighter 2 pinball machine cabinet. Overall, the cabinet is not in bad shape, expect for the bottom. It looks like moisture sat in it for a while, and the bottom is sagging pretty badly. The bottom appears to be 1/2" MDF. As you can see from the picture, there is about a 1 inch sag. Saggy Bottom...
Ive never done a cabinet bottom before. If I have to remove it, I'd like to get it out more or less intact so I can use it for a template for making a new bottom. Beside the sag, the bottom is not in bad shape. Is there a way I could mold the MDF back into shape?
How did Gottlieb attached their cabinet bottoms? Are they in a groove like Williams machines? It does appear the it is glued in place around the outside edge, but I can't tell if it is in a groove.
Thanks,
Alan
