Following up on my problematic Solar Ride that had been working happily for a couple of years, but now I am paying for not having prepped it correctly. There were some general system failures, so I am going through Clay's system 1 guide. I have not done the ground mods, but did replace the C1 cap on the power supply. Maybe I should just replace the power supply completely, but perhaps you can be the judge of how bad a shape the game is in to see what makes the most sense. I am checking the voltages and all came up right except the following:
A2-P1 pin 6,7 - 33v (should be 69vAC)
A2-P2 pin 1,2 - 0.8v (should be 5vDC)
A2-P3 pin 7 - no voltage (should be 4vDC)
A2-P3 pin 8 - no voltage (should be 8vDC)
To see if I could figure out what was up with the 69v, I read the voltage off the small transformer, with ground to lug 8 and pos to the fuse behind the transformer - got 77vAC.
So I am very confused. Is the transformer a problem? Should I just replace the power supply? Thanks for any suggestions of what to do now.
