New! Dark mode!
(Topic ID: 234334)
Gottlieb System 1 missing 69VAC at the power supply input
By Jakers
1 year ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Mombo-number-5
#1 1 year ago
I recently acquired a Charlies Angels solid state. When I first got it, it would boot up but not start a game. I re-pinned connectors A1-J7 and A1-J6 on the CPU, cleaned and re-flowed all the contact pads and did the ground mods for all 3 boards. The game then worked. I was playing for about 5 minutes and testing all the switches and coils. Everything seemed to be working but it started making some strange noise from the speaker so I shut it down. I unplugged everything and started over again with the www.pinrepair.com system 1 guide.
All the fuses check out fine and are the right amperage. The bridge rectifiers also check out fine.
When testing the input voltages at the power supply connector I have the 11.5v and 14v but the 69v is reading 0v.
I'm missing the +4 and +8 volts at the A2-J3 output.
+5v and -12v output to CPU are perfect.
What would cause the missing 69v AC at the power supply input?
IMG_8040 (resized).jpgIMG_8041 (resized).jpgIMG_8042 (resized).jpgIMG_8043 (resized).jpgIMG_8044 (resized).jpg
#2 1 year ago
AC is not measured to ground unless it is the center point of that winding. Measure the 69VAC from pin 6 to 7
#3 1 year ago
Here's a system 1 power on checklist I made based upon Clay's video. It is very specific about where to measure things. If you use it please make a copy first
https://docs.google.com/spreadsheets/d/1NV3NaXS6d696csiFSRcvi900dFwyPZSgFZfkDUwaZ4U/edit?usp=drivesdk
#4 1 year ago
There is a special transformer that likes to fail for no reason. I have seen quite a few of them fail. Would love to know why this happens when they system didnt cause it......
#5 1 year ago
Quoted from Cheddar:
Ok, so I measured pin 6 to 7 and am getting 69v and the missing 4 and 8 volts was my mistake. The power supply is working correctly. I plugged everything back together and the game plays again.
It does have some strange behavior though. It doesn’t want to add a second player most of the time and when it does, the playfield GI goes out like it’s been tilted. When I push the start button again, it resets and goes back to a one player game. I’ve never been able to get more than a 2 player game going. Also, the diagnostics botton on the inside of the coin door does nothing.
#6 1 year ago
Quoted from Jakers:
Try shorting the tabs on the switch. If that works, the internals of the switch may be corroded and you might need to replace it. Pbresource has them. Cherry e69 switch, if I remember right.
[edit]: http://www.pinwiki.com//wiki/index.php?title=Gottlieb_System_1#Accessing_Bookkeeping_and_Diagnostics
E69-00A; with links to jameco, digikey, and mouser.
#7 1 year ago
After reseating the connectors it is *mostly* working 100%. The only things now that don't work are the coin slot 2 switch and the coin door slam switch. I can start a 4 player game, get to the diagnostics menu and that's good enough for me. Thanks for all the input, guys!
#8 1 year ago
First time I've seen the system 1 check list. That's outstanding (leave it to Clay). I probably did most of the stuff but never the same twice and in a hap hazard disorganized grab-ass-tic manner. I usually would just check the connectors, piss and moan about CPU corrosion, then check fuses and all the coils to make sure they are free and moving. Turn it on, and be very surprised if anything worked at all. This list will come in very handy in the next few months for me because I found a early solid state bone yard with a bunch of lesser system 1's in it. Don't ask. Tim/Stillwater, MN
#9 1 year ago
Oop's, Cheddar guy made that list it appears. (See... I'm unorganized...but it is 5 in the morning) Props to Cheddar guy.
$ 4.00
$ 49.00
$ 289.00
$ 5.00
Allteksystems
$ 128.00
$ 11,500.00
Pinball Pro
$ 175.00
Professor Pinball
$ 5,899.00
Classic Game Rooms
$ 80.00
Back Alley Creations
$ 5,899.99
Pinball Pro
$ 239.00
$ 48.00
$ 19.50
Apparel - Unisex
ArcadeMade
$ 19.99
$ 45.00
The MOD Couple
$ 122.00
$ 7,899.00
Classic Game Rooms
$ 8.95
$ 20.50
The MOD Couple
Creo Pinball
