I recently picked up a Genie. Works but has a few bugs. No GI. Fuse keeps blowing. Figure it's a socket bent over on to itself but have looked and looked and can't find it yet.
Then there's the drop targets. Both are out. Found out the fuse was blown under the play field so I replaced it and turned it on. Fuse didn't blow but the 7 bank coils lock on. Checked the ohms on the coils and they were low. Cut the ground wire off and tested again they were testing fine.
Have brand new Ni-Wumpf mpu and driver board. Just original power supply. Wondering if anyone has ideas. And also... See the pic above... Power supply has two components cut off. Any connection? What do these two things do and why would someone remove them?
