Just an update on the display problem with Genie. If you look back at whats been said up to this point and the photos you will see that all of a sudden all 4 displays went haywire. Some very bright and unable to make out the digits, others missing digits and flashing etc. A total mess. Also the 1/4 SB fuse was blowing. Because of that I replaced the Rottendog 13 year old PS and had Ni-Wumpf check the CPU. When this first started it fried their Z6 chip. After buying the new PS I sent the CPU back to Ni-Wumpf to check. This time he said the CPU was fine.
Fast forward to today, I installed the new PS and CPU and now #1 and #2 are fine, #4 did not work at all, and #3 is missing a digit.
To see if it was the #4 display that was bad or if it is a pin/power problem, I moved it to another spot and it still did not work so that display is shot. I moved #3 with a missing digit to another spot and it worked fine so the #3 spot has to have a bad pin or something. Crazy how one second all was fine then this mess. Seems like it was a bad PS that caused the initial problem. Man oh man I cannot believe the power of the new PS! Its like a new game as everything is fast ans powerful. I should have replaced that awhile ago with the other boards.
So at this point, for now, I can play the game with just player 1 & 2 as they are fine. I guess I can either replace all the displays with digital ones for a couple hundred bucks or maybe find one replacement original display if that is even available. Either way I still have to find out why the #3 display has a blank second digit. If anyone has any suggestions I am all ears. I have PinWiki and the Genie manual to help me but am hoping someone here might have dealt with this problem and can lead me quickly to a place to look. The pins look fine so will start looking upstream. Thanks to all who have helped me.
