(Topic ID: 59847)
Gottlieb System 1 Cleopatra - Needs some TLC!
By MArmour
10 years ago
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 10 years ago by MArmour
#1 10 years ago
Hey guys,
I recently picked up a SS Cleopatra that is in need of some serious TLC. I have been trying to follow the power up process from pinrepair.com and I want to verify exactly where my issue is currently. I am not getting anything from the displays at all. I have tested to the voltage at the display fuse (from the fuse holder to the ground strip adjacent) and got 35V. Should this not be ~70V? I tested the display voltage output on the power supply and it looks like I am getting nothing at all there.
I am assuming the issue lies with the power supply. What should I test from here?
#2 10 years ago
No ideas?
#3 10 years ago
You measured the voltage incorrectly. At the fuse it is AC not DC, so measuring to ground isn't a valid measurement.
You start at the power supply. Remove the connector that goes to the CPU and then power up the game and make measurements. If the power measures good, and the game isn't booting, that is, you do not see control lights you have more work to do. These games have connector problems.
Does the CPU have corrosion from the NiCad battery? Has the corrosion followed to the CPU to driver board connector, and maybe even down to the driver board?
You will have to replace electrolytic caps on the power supply or replace it with a modern design replacement. If the CPU has a problem, I would sell it and buy a Ni-Wumph board. It just isn't worth the time and trouble of attempting to repair a Gottlieb system one CPU. Then if it breaks after a few hours of play you go through the trouble again.
#4 10 years ago
Also, the power supply is the small board on the left side located in the back box, not in the bottom of the cabinet under the playfield.
#5 10 years ago
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_1
Good place to start with regard to system 1's.
With a real old System 1 that has not been maintained, look close at the MPU and see if it has corrosion all around the lower left corner and that the battery is not leaking all over. If you have either of these things, then you have a lot of work ahead.
Then follow the wiki and check power into the MPU.
Make sure you do all the ground mods too.
#6 10 years ago
I got pretty lucky on the battery front. I don't see any leakage at all and little if any corrosion.
I recapped the power supply and grounded the negative side of C1 to the backbox ground plane. I am still not getting voltage on the 60V pin at all. Testing at the pin to the negative side of the cap.
I tested the A2-P1 pin 6 (69 volts AC (blue/wht/red)) to the negative side of the C6 cap and got 0 volts AC. I tested the A2-P1 pin 7 (69 volts AC Return (org/wht/red)) and got 32ish volts AC. I tested at the power supply connector and at the transformer and got the same readings. This leads me to believe that I have a bad transformer. Would this be correct?
#7 10 years ago
Be sure when measuring AC you do not ground your meter to test. You are testing those AC voltages across BOTH AC inputs/outputs correct?
#8 10 years ago
You still are measuring incorrectly. It is highly unlikely the transformer is a problem.
At the power supply, remove A2P2 and A2P3 (top and side connectors) Power up.
Set your meter for AC.
On the bottom connector A2P1 that remains connected to the power supply measure:
between pins 1 and 2 and you should read 11.5 VAC
between pins 4 and 5 and you should read 14 VAC
between pins 6 and 7 and bingo you have 69 VAC.
Be care you don't short between pins making the measurements. Pin 1 is left most on the connector.
Now move to the power supply outputs - all are DC.
Top connector location A2P2:
Pins 1/2 and ground should be 5 VDC set voltage to 5.1 VDC using POT top right.
Pins 6 and ground should be -12VDC (negative 12VDC) Needed for obsolete spider chips
Pins 4/5 are grounds
Side connector location A2P3 (display voltages will not prevent MPU/CPU boot)
Pin 1 to capacitor C6 ground 60VDC
Pin 3 to capacitor C6 ground 42VDC
Follow PINWIKI after doing power checks and ground modifications
#9 10 years ago
I tested on A2P1 and found that pins 6-7 are only reading 35VAC. I tested at the transformer and found the same results.
I tested by connecting a lead on each pin and using the 200VAC setting on my meter.
#10 10 years ago
Given your results it appears your transformer is short on voltage for the displays. What about the other voltages? The function of the game is the sum of all voltages being correct.
The display voltage problem will not prevent the game from booting and playing.
It is possible the tranformer is wired for 220AC input depending upon where you acquired the machine or it's previous background. Which would account for 35VAC vs 69VAC. However, the other measurements would also have to be 1/2 of expected value. Are they?
#11 10 years ago
Okay, so I think I found the real issue.
I tested all the pins on the power supply input and they were all around 20-35VAC. Way above what they should be for the first two sets of pins and all really close to each other. So I went back through the chain and retested the bridge rectifiers. Not sure what happened or if I just tested them poorly the first time but they are both reading as shorted out now. So I need to replace those and see how it goes from there.
Hopefully it will just be these cheap parts and the machine will be at least playable until I can start on a full clean/restore.
I will get the parts and report back if that solves the issue.
$ 7.50
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-system-1-cleopatra-needs-some-tlc and we tried optimising it for printing. Some page elements may have been deliberately hidden.
