I know that this issue has been gone through several time in "usual places" but I haven't found solution to my problem. My Cue Ball Wizard has issues with switch/light-matrixes, no life at all. When I boot up game, it goes to attraction mode nicely but that's about it. I can go to menu with that yellow button but that is only button that works. I have fixed similiar problem at one other Sys3 with changing MPU-board but now I'm stuck. I have 2 MPU-boards but either one works correctly. Driver board has almost all transistors replaced (originals were those BUZZ72's) and it's working ok (tested with that previous sys3 game). I have replaced U11 chip (display was garbage before that), dallas-chip is like new so no acid damage (now it has battery holder). Jumpers for eprom are correct. I have manual if you need some details from schematics etc., just let me know. Oh, forgot, flippers has power, some point at menu I'm able to flip those. Also flashers works fine (at test). Tournament mode-switch is not doing anything. And fuses are ok, double checked and changed F6 just in case.
