I picked up what appeared to be a nice Diamond Lady a couple days ago. The machine would not boot up. There was some previous battery leakage damage, as well as a very poorly hacked daughter-board hack, (the daughter-board is actually missing).
I installed a known working MPU/daughter-board. The machine booted up fine, displays/lamps all work. The only thing not working was the left drop target bank, which, I figured is probably caused by a bad transistor.
Anyways...
I had powered the machine off/on several times...everything seemed fine. I turned the machine off, and had wiped the playfield down, just doing some initial cleaning.
I go to power up the pin and it won't boot up. It's doing the exact same thing as it did when it had the original MPU installed. The backbox light is on, some of the PF GI is on, and a few of the inserts are cycling through the attract mode. No Display, no LED blinking on the sound board.
I figure whatever caused the original MPU board to not work has now done the same thing to my known good MPU board.
I'm not at all familiar w/ these Gottlieb pins.
Any ideas as to what to look for?
Any help would be GREATLY appreciated....This really looks like it will be a super fun pin to play, (I like drop targets).
