Hello,
Gottlieb Mario Andretti with Sys 3 boards. All sound is out otherwise game is fine. Solid red on main sound board (actually it pulses at the normal rate but it is barely noticeable unless the room dark). Aux sound board has no LED. Removed aux board and hooked up separate 5v supply to the aux board and LED comes on. I did find a pin on the ribbon cable between the two was broken and looked like it had been previously repaired. Waiting for new cable. In the meantime my research seems to indicate the main board should "work", as in flashing LED, without the aux board attached and one of the most common failures is one, or both of the static ram chips on the main sound board (MA-1629). I'm trying to obtain a set of test ROM's loaded with MarAlb's test code. I don't have a way to burn the ROM's so I'm trying to find someone who can supply me with a set of test ROM's already burned. I'm located in northeast Ohio.
Greg
