I have a Freddy pin that has been acting strange. Backbox GI was not working. Replaced the blown fuse in the cabinet and the backbox lights started working. Some of the flashers are not working, I am assuming some of these are socket issues that I can fix by replacing sockets, but there is one set of sockets that only work when there is one flasher bulb installed instead of two (boiler room has two flasher bulbs, but it will only work if one bulb is installed. As soon as the 2nd bulb is installed, the illuminated one goes out ) Also one of the flashers in the back box is very bright and constantly lit full brightness with a little pulsation. Another flasher in the backbox glows orange even when it is not flashing. The boiler room flasher also does the same.
Here's the kicker. If I raise the playfield up enough where it is not resting on the metal frame cabinet support, the flasher in the backbox that illuminates constantly at full brightness, goes out and starts blinking like it should. Also the boiler room flasher and other flasher in the backbox that glow orange all the time stop glowing orange and flash like they normally should. If I lower the playfield so it is resting down all the way on the metal frame, the flasher goes back to constant full brightness again and the boiler flasher and other backbox flasher glow orange even when not illuminating. It does this over an over each time. Even if I barely move the playfield. Seems like something is shorting out in the cabinet to the frame maybe. I did read about doing a ground mod which I plan to do but haven't yet. Do you think the ground mod will fix this flasher issue? Any ideas why the flashers are not working if both are installed in the boiler but work if only one is in and the playfield is raised.
Also freddys eyes are not lighting up no matter what I do with the bulbs. From my research there is a transistor that controls the eyes. I don't have a manual ( one is one order), can anyone tell me if q21 is the transistor for the eyes so I can check it? Hopefully these are easy cheap fixes, I have a LW3 I need to shop pit and will be getting a TFTC within the next few weeks I am going to want to do some modding. Thanks
