(Topic ID: 135381)
Gottlieb Sys 1 solenoids not working
By Vannos
5 years ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by Vannos
#1 5 years ago
I have a System 1 Dragon with the solnoids not working that i'm trying to fix.
First off, the game boots and enters attract mode. I can coin up and start a game.
If I plug in any of the coils they lock on, including all the 3 tones. The relays do not lock on but do not function. All CPU controlled lights are working correctly. When first working on the machine, the coils were fine but after 5 mins of leaving the machine idle the issue started. I've since swapped in another CPU and another driver board which displays the same issue.
Here's additional info:
- Connectors have been repined.
- Cap C17 on the CPU has -11.84 V. Is that good enough?
- I doesn't seem like solenoid buffers Z6/Z7 are the issue (because I've swapped out the whole CPU and driver and the issue is still present.)
- Momentarily gounding one of the relay transistor tabs fires the relay.
- A battery is not installed and the 0-10 audits have junk values.
Can anyone offer any insight into what the problem might be? Thanks!
#2 5 years ago
oops never mind sorry i missed part of your post about already having -12v
#3 5 years ago
The -12v is a little low, do you its within acceptable range?
#4 5 years ago
I've swapped in a different power supply which produced -12.1V and the problem still persists. So since I've tried a different CPU, driver and power supply and the issue remains, I don't think i'm dealing with an issue in the board set.
I've checked the bridge rectifiers, they seem fine. Wiring and sockets and pins seem all in very good condition.
$ 289.00
$ 49.00
€ 8.40
$ 50.00
$ 12.95
COINTAKER.COM
$ 29.25
The MOD Couple
$ 7,499.00
Nitro Pinball USA
$ 9.99
Tools
PinShield
$ 4.00
$ 12.99
Bent Mods
Pin Monk
$ 11.95
$ 54.99
$ 59.00
Pixels Arcade Games
$ 99.99
$ 45.00
