Quoted from 4Max:Hi, the power lead on my project Charlies Angel's is history and I dont trust any old connections.
I have a new one, but does it matter which way round the live and neutral attach to the filter box?
I searched and could not find any advice on Vids guide, etc
Thanks and Happy Thanksgiving all
Look, what I have made 10 years ago, mightbe, this helps you a bit.
If you want it as PDF in better resolution, simply send me a PM.
To answer your question, it does not matter, where which way round the live and neutral are attached to the filter box, there is still AC-Voltage. Nethertheless I would change the main switch to a 2-pole switch, so that if this switch is turned off, BOTH, L AND N are switched off and not only one of them. Or you leave the original switch in and measure very carefully, where L=HOT is, so that your HOT is switched and not the neutral.
Work careful and be cautious, HIGH VOLTAGE can be deadly.
And if you look at your photos and the schematics how criminal dangerous these machine are inside cabinet. There is always line voltage in the cabinet especially at the line filter, that is not protected against touching. I never leave the coin door open and hide the coindoor keys of all my sys1-machines. Cannot imagine, what happens, when my 6 year old son grabs through the open coindoor and touches the unprotected connectors of the line filter. Nethertheless I love GTB sys1 more than all other, I have them all.
