(Topic ID: 296083)
Gottlieb Surfer help needed
By GoldenOreos
5 months ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 5 months ago by GoldenOreos
#1 5 months ago
So I'll start off by saying i do not know much about EMs other than replacing basic playfield stuff, i work on 80's and up with no issues but EMs just always seemed like a lot to dive in to. We just got a Surfer in at work. When i power the machine on all i get is lights. Found a broken solder tab on the "AX Reset Control Relay", when i attach that back the game goes in to an endless cycle where the motor on the bottom left just spins and the stepper in the backbox does the same. the AX relay just stays on, and the Start relay keeps firing. If i dis engage AX it will kick a ball out and coils will work, but as soon as the ball hits any top inlane, it goes back into that cycle again. I honestly have no idea where to start on this or what tp even look at so anything would be helpful.
https://drive.google.com/file/d/1cAVU0Phisaw-1z779LsyQ890AH2hOYmQ/view?usp=sharing
#2 5 months ago
Sounds like you have a stuck switch, either on the coin door, or credit button. After checking that, make sure your solder joint is secure on AX. A common problem with EMs is the motor continuing to cycle. A switch on each of the scoring reels that closes the circuit at the end of the reset cycle is a common culprit. Even if all the reels are back to zero, the switch may be out of adjustment. Hope that helps. AZKenny
#3 5 months ago
If you check switches on the coin door make sure the game is unplugged. Most EMs have 110 volts on the door. AZKenny
#4 5 months ago
Quoted from AZKenny:
I know the coin switches and start button are good bc I checked those when I seen the start relay going off. I guess I'll look at the score reels and see if I can find the issue there.
#5 5 months ago
Exactly how far is it getting in the startup sequence from the Surfer manual?
For more than that, see your private message.
#6 5 months ago
I know if i add points manually to reels it will zero them out but the motor etc still does what it does in video I linked above. I wont get to look at it again until Tues. I'm guessing the reels r the culprit but probably not the whole issue who knows
#7 5 months ago
kenny's reply seems to be the only possibility unless you have a short.
if the S relay is powering, then the replay button switch or a coin chute switch would have to be closed.
if the V relay isn't doing anything, then that narrows it down to the coin chute switches or maybe a problem with the coin chute adjust plug.
when the AX relay trips (coil with the WH-OR wire on it powers), the start relay circuit is disconnected. The AX relay will reset as soon as the score motor runs again tho.
if your coin door has a plug, you could try pulling that out and seeing what happens.
#8 5 months ago
Quoted from baldtwit:
I'll try that tuesday and see what happens, thanks for an ou there possible solution.
