Gottlieb Surfer add bonus rollovers not cycling position
By Blue-el34
1 week ago
Stats
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 week ago by Raff
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 9 days ago
Hi All,
My Surfer used to change which Add bonus rollover was lit up when the spinner spun but no longer does. I cleaned and checked the spinner contacts but that didn't help. I recently tweaked the AX relay is it possible that is the culprit or should I look elsewhere. Any advice or direction is greatly appreciated.
#2 9 days ago
Does the AS relay still spin properly when the spinner spins? Does the spinner still score points?
#3 9 days ago
Quoted from Blue-el34:
... Any advice or direction is greatly appreciated.
Do you have the schematic? If not, get one.
#4 9 days ago
@zacaj
I found the KS relay with the dried remains of a rubber band around it's spring. This appears to be the problem.
Thank you for the direction.
#5 9 days ago
@HowardR
Thanks, I do have the schematic but I'm still learning how to read it. Thanks to @zacaj I now can see on the schematic that the KS relay is the obvious starting point and is indeed the problem. Thank you for your patience with a pinball noob.
#6 8 days ago
on the circuit board connected to the ks relay there is two sides , one side only controls the add bonus light , undo the two screws holding the spring take it off ,then the washer then the double sided pivots , use some circuit board cleaner give the board a good clean, then with some sand paper giver the two pivots a clean, that pivot arm give it a little bend to make sure it is making contact with board then put it back together the same way you take it off, and check it with a dmm to make sure its making contact , make sure when you put the spring arm back on that its not to tight on or the pivot arm wont move freely around
#7 8 days ago
@Raff thank you I will give this a go next time I am servicing it but for now its playing well.
PS
When I was a kid my family lived in west lakes/semaphore area sea side and I have many fond memories of Bloods matches
#8 8 days ago
footy games are not played at west lakes anymore there all played at Adelaide oval now
$ 27.99
Lee's Parts
$ 109.99
€ 379.00
Displays
GermanGamingSupplies.com
$ 128.00
$ 22.00
$ 29.99
$ 66.99
Lee's Parts
Medisinyl Mods
$ 14.00
Playfield - Plastics
Bright Lights Pinball
$ 71.99
Lee's Parts
$ 99.99
$ 5,699.00
Flip N Out Pinball
$ 28.99
Lee's Parts
$ 48.00
$ 7,199.00
Flip N Out Pinball
Apparel - Unisex
Pinball Wheezer
$ 66.95
$ 19.95
$ 495.00
MI Pinball Refinery
$ 150.00
Third Coast Pinball
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
