Novice here, so let me apologize in advance, Gottlieb Super Soccer Player, the progressive bonus lights & scoring (additional lights and increased value as game progresses) appears driven by the AX, BX, and CX relays/coils and associated switches in the Control Bank, which seem to be energized by Motor 1c. The five switches in motor 1c appear open and closed when appropriate, yet the relays are operating intermittently, once activated they remain activated, but they don’t always activate. When they don’t activate they sometimes buzz, if buzzing or not, and they don’t activate when they should if you give them a light touch they will immediately pull in and activate. You can feel a vibration as well not witnessed on the coils either activated or not suppose to be activated at that time. Is this an indication the coils are worn and need replaced or that the power sent to the coil is insufficient, again this is intermittent game by game, sometimes impacting all 3 of these relays, other times only one or two, or none. Often when I have this issue the game which is set as 3-ball will extend to add ball 4-5, although ball 5 will not add add points to score wheel. When the bonus profession works the games all end correctly after ball 3.
Thanks for your consideration,
Matt
A8901AE0-E933-4893-A8DC-88B4E5305D6C (resized).jpegD5CD5666-4D88-4978-B8FF-0889588D4011 (resized).jpeg
