Hi all,
I spent the whole weekend on one final issue with this machine, and cannot fix it...and of course have now made it worse. Not used to working on 4 player Gottlieb's and while I have the schematic, the advance player unit, plus the large relay bank, are scary!
Background: This was a project machine. I got everything working, so that it played a complete, correct game for 1, 2 or 3 players.
If you tried to add a 4th player, the PB4 (player 4) relay pulled in correctly, but no player 4 light came on, and at the end of player 3 ball 1, it just skipped to ball 2 player 1.
I'm sure there was more than one issue here, because I thought the easiest test was the player 4 lamp. The lamp works as it comes on for Game Over (XB), as per the schematic, surely just close the switch on PB4 that has Yellow and Black/Red
When I jumped them, no lamp. I jumpered the other switch that "should" be closed - still no lamp. Hmmm
Although it would not fix the above, I noticed that the swiches close nicely when the relay back is flipped up, but do not when they are back in the seated position.
Question 1: does anyone have a PB4 - are these switches missing a space or something?
IMG_4079a (resized).jpgI have tried adjusting them for hours so that the are "really" closed when PB4 is engaged, but when I put the bank into its seated position the bar pushes a little and the switches are then not made.
I know Clay's guide talks about this - but I really cannot get them to stay closed when the bank is down - any thoughts?
Of course, I thought I could adjust the relay bank (there are two screws on each side), tried moving it around a little, no joy, put it back, and now:
Press Credit button once - all ok (can play a complete 3 ball game)
But, press credit button again, instead of moving to player 2, the game goes through its full reset back to ready for player 1 again - ARRRRH!
I am very sorry for the long post, always a fine line between too much and too little info.
Summary, working backwards:
1. Anything obvious to check that now causes it to reset when pressing credit button twice, rather than adding player 2?
2. Any advice on the lower PB4 switches, getting them to remain closed when relay sitting in locked down position?
3. If I get those fixed, then I can look at why no Player 4 is being added
thanks!!!!
