(Topic ID: 219449)
Gottlieb Super Score - misc troubleshooting - my first EM
By winteriscoming
1 year ago
  • 15 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by jeffc
#1 1 year ago
I've done a quick read the PINBALL Repair EM guide and will start making my way through the recommended steps there, but I wanted to log my issues and progess.
Gottlieb Super Score is my first EM. I bought it with the head removed and had it that way until yesterday when I got to spend a little time assembling it and trying to figure out how it works.
Once plugged in, the game powers on when I push the center button on the coin door.
A couple issues that I've fixed so far:
Right flippers not working - Coil lost its plunger/link down in the cabinet.
Two of the pop bumbers on the same relay were locking on. This was caused by one of the switches not opening when the pop-bumper was active. I also noticed a switch in the relay that appeared to be purposefully bent back such that it wouldn't make contact. I went ahead and gapped it properly so that it would make contact when the relay is active.
Some remaining issues:
-The 2 switches in the outlanes on the right don't seem to be registering.
-P1 10 point reel does not spin, but instead seems to get applied to P2 10 reel. I'm not up to speed on the workings of reels, but if I keep hitting a 1 point switch all the way up to 10, the 1 point reel resets to 0, but nothing happens with 10 - not even P2 10 increasing. Advancing P2 10 all the way up does nothing to P2 100. When I push the button on the center of the coin door, the game resets (I think), a ball is ejected, and P2 ends up with points in the 10 slot.
-I'm not sure about the status of the lights that I think indicate the ball in play. As it is, I don't think the game ever ends. It keeps ejecting a new ball when drained, and it always seems to be P1, though I'm not sure at the moment what indicates the active player and the ball in play.
This what I'm noticing so far. I'll document progress when I get a chance.
Other than those issues, pf lights seem to be working correctly, and I'm happy to see that the roulette wheel seems to be functioning properly, too.
I still need to clean the plugs which I gather can clear up a lot of issues, so that probably needs to be a next step.
#2 1 year ago
You're making good progress there, and it's not clear to me if you want help or if you do, which issue(s) you want help with.
#3 1 year ago
Quoted from HowardR:
I'm not sure yet how to ask the right kinds of questions.
Part of me wants to see if I can figure this out on my own, but I'm not very familiar with EM theory yet, so if any issues stand out to an expert as meaning I should check out something specific, I would welcome that feedback.
#4 1 year ago
Not an expert, but I have brought a few EMs back from the dead. It sounds like you are going to get into dealing with those stepper units for the ball in play and lack of player lights. The stepper units should function smoothly when you manually activate them. The "fingers" are what make the electrical contact and do things like tell the machine what ball is in play etc.
The score reels not advancing the next digit is probably related to the switches on the score reels that make contact when in the 9 position which close the circuit to fire the next digit's coil.
It is a little daunting at first, but I usually disassemble the stepper units and score reels for cleaning. I clean off the old solidified grease with alcohol. Take pictures and try to take them apart and put them together in the reset position.
All this info is in that awesome EM pin repair guide.
Honestly, I love working on EMs more than SS machines. Good luck and have fun! If you don't have the schematics yet order them from PBR who have the best selection of parts etc. for EMs especially Gottliebs.
#5 1 year ago
My approach is a little different. Until you get enough experience to not need advice, diagnose one problem at a time and only then, fix only that.
Tools you'll need that are mostly different from Solid State:
Schematic (the manual is a nice-to-have)
L Contact Aduster from http://www.pbresource.com/tools.html
Plastone or Flexstone also from http://www.pbresource.com/tools.html
Alligator clip jumper wires from https://www.radioshack.com/products/radioshack-30-76-2cm-test-jumper-leads also available on Amazon
#6 1 year ago
OK, not ignoring advice on getting schematics, but it might be a bit before I do.
There's a balls played stepper unit in the head that was misaligned such that it was making no contact in the reset position. I realigned it and the game starts in 1P mode, the lights for 2P go out, and the ball in play lamps are working correctly. Also, scoring for P1 is fixed, including all positions as well as advancement from one digit to the next.
The next issue is that the balls played unit is neither advancing nor resetting. If I manually move the plunger on the coil that advances the unit, it steps through just fine, and I can reset it by manually pushing in the reset coil's plunger, so I don't suspect a mechanical issue there. I would guess it's an issue with whatever drives these 2 coils, which I should be able to trace out.
If I put the balls played unit in something other than the reset position, and I push the button on the front of the cab, it keeps cycling through what I guess is the reset procedure for the game and isn't satisfied until I manually reset this balls played unit.
I think the balls played unit is my main focus, but I also still have 2 outlane switches on the right not working, and the switch at the end of the shooter lane that would be activated when plunging the ball isn't working.
I also notice that I get 50 points for a ball hitting the drain hole. Not sure if that is supposed to happen.
The last issue I can think to note is that upon resetting with the button in the front, I start out with 10 points.
#7 1 year ago
Quoted from winteriscoming:
#8 1 year ago
Nice, I can see how schematics would be helpful on these!
One of the switches on the stack that senses whether or not the balls played unit is zeroed was not making good contact. That has been corrected and the unit now appears to reset as needed.
It does not appear that the unit is advancing, though. There's a relay down in the cab labeled as B - Change Players/Add Balls Played Relay. I can manually trigger this relay and the balls played unit does advance. So it seems be a matter of tracking down what drives this relay and figuring out why that isn't happening.
One thing that's not clear to me is whether or not the zero position of the balls played unit is supposed to be before P1 Ball 1 where no contact is made (how it was when I got the game) or right on it (how I adjusted it when I thought it was out of alignment).
I am enjoying this EM troubleshooting so far. It's not entirely different than solid state. It still seems to be a matter of identifying what's not working and figuring out what drives it.
#9 1 year ago
9 games in your collection, nice! How about a picture of your game room?
Spoken like a true scientist. (which is a compliment) That's how I think about it.
#10 1 year ago
It's an unfinished basement that's kept in a constant messy state from all of my projects... photos will not impress!
#11 1 year ago
Do the letters in the diagram indicate the switches in the relay with that letter?
So if I'm reading it the way it looks to me, Relay B's coil is activated if a switch on Relay C is closed, and trough switch is open?
#12 1 year ago
Yes
Both of those switches have to be closed for Relay B's coil to activate
#13 1 year ago
That makes more sense that it would have to be closed, since that would complete the circuit, but what's the difference between a switch that appears open in the diagram and one that is slashed through?
#15 1 year ago
Also note that Gottlieb schematics are drawn to represent the state where a game is started, everything reset, ball served to plunger lane and then the line cord is unplugged.
600
Duanesburg, NY
$ 279.95
PinBoss Mods
German-Pinball-Modular
$ 8,000.00
Flip N Out Pinball
$ 48.00
$ 229.00
PinballBulbs
$ 79.95
$ 12.50
$ 369.00
Pinball Photos
$ 129.95
Hookedonpinball.com
$ 48.00
$ 399.99
Top-Notch Target Shields
$ 130.00
Rods Mods
$ 7,299.00
Flip N Out Pinball
$ 10.95
$ 23.75
The MOD Couple
