New! Dark mode!
(Topic ID: 270808)
Gottlieb Subway Tilt issue..
By tscottn
5 months ago
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 5 months ago by tscottn
#1 5 months ago
Ok, so.. now that most of my issue are worked out and the game plays great I can see one last problem. The tilt is not working the way it should. When I tilt a game, the rules are as follows; lose that ball inb play plus one additional ball. so lets say on ball 5 I tilt, the game should drain ball 5 and start me on ball 3. this is actually happening the way it should with one issue, the player unit will move to ball 3 position however nothing will light up on the back box and the tilt light stays on, no action on the PF and the trough switch will not open to let the next ball through.. . If i manually drain ball 3 the player unit will move to ball 2, but still no action on the back box, flippers or PF. then if I manually drain ball 2 it will go to ball 1 with same scenario, then if I drain ball 1 the player unit will move to the zero position and game over will be displayed on the back box.
So part of the tilt mechanism is working correctly and part is not. Looking at the schematics I attached, it seems there is switches on the D and S relay as well as motor 4c. They all look to be in good shape. One last thing, moving the tilt plug to in or out makes no difference in what I just posted. Both positions have no effect. Would anyone have any ideas?
#2 5 months ago
bump for anyone who might have any ideas?
#3 5 months ago
Quoted from tscottn:
So the Tilt relay trips and doesn't reset. Is that right? The Control Bank Reset solenoid above should fire to reset the Control Relay bank after the ball count is changed.
I think the path you need to investigate is the upper path into the Control Bank Reset solenoid in your schematic above. For the Control Bank Reset solenoid to fire:
- a switch at Score Motor 4C needs to close, which implies that the score motor needs to turn
- switches on the O relay and T relay armature need to close too
You'll need to diagnose this circuit either with alligator clip test leads or a multimeter. Visual inspection can prove that switches don't close, but can't really prove that they do close with adequate electrical conductivity.
/Mark
#4 5 months ago
Quoted from MarkG:
/Mark
Thanks Mark.
So in regards to what you posted. The score motor will not turn after the tilt happens. Like I said, I still get the player unit advancing balls but the score motor will not turn. I can turn it manually and if I do, the control bank reset will still not fire. I will have a look at T and O relay with alligator clips to ensure they are closing properly.
#5 5 months ago
Player Unit or Ball Count Unit? Either way I suspect it's a Score Motor switch that's advancing the stepper and subtracting the two balls. I don't have the Subway schematic but I think that the Control Bank Reset solenoid should fire when the the Score Motor 4C switch closes which is probably just after the two balls have been subtracted but on the same Score Motor cycle.
This is a chart from another game but you can see that in this case the 4C switches activate at the very end of the cycle. The Ball Count could be decremented with any of the earlier pulses in the same cycle.
#6 5 months ago
Quoted from MarkG:
/Mark
Hey Mark, I finally got around to looking at this based on your suggestions I started jumping all switches involved. It finally turned out to be the switch on the T relay that was not making contact when the tilt reset the control bank. So even though the score motor advanced on 4c and the ball count unit was working as it should, It couldn't energizer to reengage the control bank. After adjusting the switch it now works as it should. Thanks again!
$ 50.00
Cabinet Parts
Flashinstinct
$ 150.00
Great American Pinball
£ 45.00
PinballToys
$ 69.99
$ 47.00
Filament Printing
Playfield - Plastics
Ramp-O-Matic
$ 40.00
B & K Mods
$ 48.00
$ 95.00
pinballmod
$ 27.99
$ 40.99
Lee's Parts
$ 239.99
PinballBulbs
$ 149.00
£ 31.00
PinballToys
$ 839.00
YouBentMyWookie
$ 21.95
Apparel - Unisex
Pinball Wheezer
$ 48.00
