This may help:
https://pinside.com/pinball/forum/topic/webbing-of-the-day#post-3344556
Did my first webbing on a Mibs - used Ken's technique.
HF touch up gun ($13-25%)with a added cheap-o plastic regulator ($3) and moisture filter ($3)
Lacquer Thinner (@HD- $13 gal.)
Montana Black $pider $pray Paint ($8 small can) - couldn't find any Krylon, spayed into reservoir (maybe an ounce plus) and added almost the same amount of thinner
3 gallon compressor @ 60psi
Previously primed/painted base coat. After final coat was barely dry to touch I mixed the webbing and practiced bursts on cardboard. Saw what I wanted with gun about 6 inches from surface using very short blasts, everything wide open. Moved directly to cab. Could do the entire head before the tiny compressor kicked on.
Beautiful very fine webbing nearly identical to what I saw on the 'protected areas'. Tried a few longer bursts and had a slightly thicker strand similar to that on my 72 Grand Slam. On the new paint it 'melted' in slightly and adhered well. If too far away some strings will not adhere and fall off. Sticks better if cab is not fully cured and surface is not cool. I very slightly overspayed and ended up with a great look.
When I decided to paint this cab, webbing was my greatest concern. I envisioned attempt, fail, sand, paint again, try webbing again, repeat also didn't think my 3 gallon was going to cut it -- when it looked so good on the first shot I nearly ----.
I just need to fig a better less messy way to get the spray paint into the gun's reservoir.
Cheers
-- Tom
