(Topic ID: 290977)
Gottlieb Spirit of 76 not registering coin credits
By ZappaMan
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by ZappaMan
    #1 3 years ago
    So I've been playing the machine with the coin chute just fine until recently when it suddenly won't work anymore - I put a coin in and the score motor just turns once and nothing else - no credits added. I then decided to put it on free play and that works fine but I really want to have the option to go back to coins. Can help please?
    #2 3 years ago
    The mech likely needs adjustment.
    Document_2021-03-30_081054 (resized).jpgDocument_2021-03-30_081054 (resized).jpg
    #3 3 years ago
    Hey currie! Since the op says the score motor is turning, I wonder if that means the coin switch is OK since it's turning on the W relay (which starts the score motor). I wonder if there's a problem on the W relay, since there's a switch there that energizes the replay unit - or any of the switches in series with that m/b switch in the add replay unit circuit.
    sof76 (resized).JPGsof76 (resized).JPGsof76 score motor (resized).JPGsof76 score motor (resized).JPGsof76 replay (resized).JPGsof76 replay (resized).JPG
    It could also be a switch on the S relay not turning on the W relay, depending on how he has the 1st coin chute adjust set. Either way, the W relay has to be energized to add a credit, I think.
    #4 3 years ago
    Quoted from paulace:
    Excellent point, Paulace.
    #5 3 years ago
    Quoted from ZappaMan:
    What was the behavior before it broke? The dropped coin resulted in multiple credits being added? Or did the dropped coin start a new game immediately?
    Those are the two correct behaviors, depending upon which coin slot the coin was dropped in and the settings for that coin slot (1 coin 1 play vs. 2nd chute). 1 coin 1 play bypasses the credit up/down logic and just fires the start relay, beginning a new game immediately.
    #6 3 years ago
    Hey DaMoib - yeah, I see that now - the W relay is skipped altogether when the 1 coin 1 play is connected and the #1 coin chute is used.
    #7 3 years ago
    Hi, thanks for your replies..I'm using the second chute (as the first chute is blocked for now) and on multiple credits (3) - coin goes in the W relay energizers and score motor turns and no credits..I tried cleaning the switches on the relay but no luck.
    #8 3 years ago
    Ok I've got it working on 4 credits and 5 credits now but not on the 3 credit plug - could it be switches on the score motor need adjustment?
    #9 3 years ago
    Yes, your motor 4C switch or motor 4B switch is probably not working correctly. Look at the schematic snippet below:
    The 4 and 5 credit settings bypass those 2 switches - the 2 and 3 credit settings need them to make a connection, so I'd imagine that's where the problem lies.
    #10 3 years ago
    Thanks, cleaned the switches on 4B and 4C and now giving credits again!
    This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-spirit-of-76-not-registering-coin-credits and we tried optimising it for printing. Some page elements may have been deliberately hidden.
