New! Dark mode!
(Topic ID: 276561)
TECH - Gottlieb 'Spirit of 76'
By meSz
88 days ago
  • 102 posts
  • 6 Pinsiders participating
  • Latest reply 9 days ago by fredsmythson
There have been 47 images uploaded to this topic. (View topic image gallery).
There are 102 posts in this topic. You are on page 3 of 3.
#101 9 days ago
Started to look at what you typed Rolf. I put a score up on player 1
Then I went in and manually set the Player Unit as you advised.
Then I started the machine and no change. The bank of Rollover relays engage but game doesn’t start.
Unfortunately it was at this point my wife had people over and the beers started to flow. Furthermore I am now on a plane heading back East for 6 weeks. So I won’t be able to do anything else till I return.
Very much appreciate the help and feel free to post anything else that may be helpful as I will be checking in.
#102 9 days ago
You'll need to find out "when" the reset process stops.
Check the 1st ball relay (U relay). When you press the credit/start button, does the 1st ball relay coil energize?
Then check the coin unit. When you press the credit/start button does the coin unit advance to the next position?
Test the coin unit by first manually advancing the coin unit to the 3rd or 4th position. Then press the credit/start button. Does the coin unit reset to the 1st position?
Does the AX relay move (trip/latch) during the reset?
Here's a video from Clay's Pin Repair Web site that explains the changeover to the AX relay system and how the AX relay works:
http://www.pinrepair.com/em/index3.htm#axrelayvideo
$ 14.00
$ 39.00
Concealed Art
$ 17.99
Pinball Mod Co.
€ 339.00
Displays
GermanGamingSupplies.com
Metal-Mods
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 95.00
pinballmod
$ 5,899.00
Great American Pinball
$ 18.99
Bent Mods
Creo Pinball
CzTV Mods
$ 229.99
$ 8.00
Cabinet Parts
$ 24.25
The MOD Couple
$ 47.00
Cento Creations
$ 12.00
$ 85.00
Loop Combo Pinball
$ 19.25
The MOD Couple
$ 54.99
