Just got the parts to try and repair the Bonus Stepper Unit which had missing the wiper assembly and the gear/shaft. Got it put together and trying to get it to work. The Bonus Unit seems to be doing nothing. When I reset the game it completes it's reset but the ball kicker will not kick the ball out. The switch doesn't seem to do anything. Turns out that part of the switch stack at the Bonus Unit is tied into the kicker circuit, I think. It looks like *if* the bonus unit was running when the stepper goes through all 15 steps it closes a switch (and opens 2 closed ones) at the stack. When this happens, the kicker kicks the ball out, then the ball travels over another switch on the way to the outlane. That switch seems to set the ball count (or tell the ball count unit to do it) and also resets the Bonus Unit. When the ball drains again, nothing happens at all, the same as game start. I have to close that switch on the bonus switch stack to make something happen. So, when the kicker's switch closes when the ball drains, what should happen? What relays are involved or ?? Trying to read the schematic and getting slowly better at that but not very good yet.
To make sure of something, at that bonus stepper stack, there are 2 outer switches that are closed and then a single inner blade that gets closed when the wiper gets all the way around and opens the first switch which causes one of the switch blades to touch, ie close, the center switch, like this I think. These looked all bent out by the previous owner, looked like he was bypassing the bonus unit completely.
before unit runs blade1<->closed<->blade2<->open<->blade3<->open<->blade4<->closed<->blade5
at end of 15 steps blade1<->open<->blade2<->closed<->blade3<->open<->blade4<->open<->blade5
Feel like I am getting closer, but alas not there yet.
Help, David
