Another pin that is almost 100% working, but have some demons to track down still. Right now I'm trying to figure out how to get the 500/5000 points roll-over switching to work correctly. At the top right the are 2 lanes that work together and then the lower left and right outlanes work together sort-of. If the light is lit you get 5000 and if not 500. The scoring works for all the lane switches finally. But the scoring between 500 & 5000 is supposed to alternate between lanes after rolling over the switches from the way I understand it. There is a Relay "A" on the underside of the playfield that seems to control the light and the scoring for this function. If I engaged the relay, hold it in, the lights and scoring switches to one lane and if I don't do anything the light and scoring is in the other lane. What doesn't seem to be happening though is the Relay never engages on it's own. There is a coil on the relay and maybe it's bad, need to check that next. Not sure after the coil though what could be happening. The is a switch on the Motor and the A Relay seems to connect to a switch at position 2C. Hard to get at that switch, wondering whether that would be the next place to look after checking the coil or somewhere else?
Ideas?
