I'm having issues with a Gottlieb Soccer EM. The main issue appears to be that the player unit coil isn't getting power and firing. The machine coin ups press the start and I might be missing some here. I know tilt relay engages the S relay engages then releases. the SB and SB2 engage and hold in. The score motor just continues to run. I can manually fire the player coil and the arm moves and it will reset the scores ones its in the correct position. If I manually move the reset bar the motor will stop and most of the playfield is live. I also checed 1A on the score motor cleaned it and is making connection as the moter turns. I have the schematics for this but there seems to be different paths to the player coil and at this point I'm not sure what one I should be looking for. At this point I feel I am going in circles. I looked at some of the startup gudies as well and still haven't had luck. If anyone has ideas or can help its greatly appreciated. I really think its just one switch that's the issue, but witch one?
Thanks in advance.
