RSTrunks, if you don't have a schematic, here is my Super Soccer. Assuming the 4 player version is similar when it comes to the outhole, this may help:
The upper green line shows the circuit for the kicker - which you say works when manually operating the O relay.
The red line shows circuit to operate O relay. As TimMe says, there's a number of switches that have to be closed for it to pull in:
From right to left on the schematic:
a NC (normally closed) Anti-Cheat Switch (the right hand side of this leads to the 25v TimMe mentions, via a 15A fuse that is (on mine) a Red wire with Green trace (the reds often fade!)
Motor 2B
Motor 1C
NC on the GX relay
Ball Return Switch (you checked this one)
A make/break switch, that needs to be closed at zero position of the bonus relay (meaning bonus has to count down to zero for this switch to close before kicker fires)
NC on relays E, SB1 and QB
So, I would check the easy ones first (and the ones that move more than others) - the two switches on the score motor, and the zero position switch on the bonus relay.
Next clean the NC switches on all the stated relays, or use a jumper wire to start to eliminate switches until you find the culprit.
I know from very recent experience the switches on the large relay bank are a pain to adjust - hence I'd leave those till last, or use the jumper wire to see if you can narrow it down.
