Ok, my Scuba plays fine, but none of the pf inserts light up. All I have done is clean, reseat the jones plugs.... Any ideas?
Thx
Thx
Have the schematic? Pick an insert light on the schematic, and work backwards (right to left), following the logic to see what switches are involved, then check them. Maybe there's one make/break switch that's off.
Is it on both players or just one? Check the A and B relays (under the playfield) to see if the little "finger" moves when you get to the next plateau.
Back to this, sorry, was in the bathroom for a bit.
So, no plateaus can be achieved, and no inserts light on the pf, but pf gi works, and target lighting works. Same for one or two player. Just went through wiring, cleaned all jones plugs.
The plateau lights go through the Player A and Player B Relay discs. Check to see if they are advancing. If neither advance the switches that they have in common are on the S Relay and SB Relay. So check if all switches are opening and closing correctly on both of those relays.
If that doesn't work get back with us in 4 years
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-scuba-insert-lighting-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
