Check to see if there is a relay on the control bank labeled "reset completed" or something like that. It often has an ID letter of "D" or some variant of "D". If you have this relay on your control bank, it should latch in the up position with all the other bank relays at the start of a new game, and it should not trip until all the score units are at zero.
It sounds like this relay is either never latching in the up position, or is tripping immediately. If it is never latching properly, there is probably an adjustment or mechanical problem with the relay itself, such as a broken or sticking relay armature. Also be sure that the control bank relay frame is fully and properly seated into the support brackets on both sides of the frame.
If it is latching properly but then electrically tripping immediately, there are a few reasons that could be happening. One reason would be a circuit fault somewhere in the runout switches on one of the score units.
Since you've checked the score units already, try checking the tilt relay or game over relay to see if there are any switches out of adjustment there. There is usually a switch on one of these two relays (most often on the tilt relay) that forces the reset completed relay to trip in the event that the game is tilted while the score is resetting.
Finally, check the motor 1C switch stack to see if there are any circuit faults between switch blades there. The reset completed relay is usually triggered by a motor 1C switch closing, to ensure that the reset completed function does not terminate until the motor is back to the home position. If 25 VAC is accidently getting shorted onto the reset completed switch blade on the 1C stack, then the reset completed relay could trip immediately.
- TimMe
