Alright!
Took the day off today to begin on the cabinet assembly.
So first I had told you about the side panels fitting a little too snug. Fixed that with the router:
S'all good, man!
Then to check if all the pieces fit together as they should before I start gluing stuff.
Yup, good to go, except for this - too snug again. Will shave them off with the saw.
Done!
Ready to glue things together - 12 glued cabinet tops, the train is coming!
While this is drying, I figured I'd give a slight mineral oil wipe down to the inside wood panels. Some people will probably do translites, but if you don't I want it to look good.
With the glue dry, the cabinets then need to be sanded flat on all sides. I wish I had a large industrial belt sander, but for now this is what I'm doing:
That poor vacuum can't keep up:
I have brown hair by the way, this is MDF dust
Merry Christmas!
Then after blowing compressed air to clean them up:
Next up is wood filler to get everything nice and clean, but no pics of that yet.
I'm taking note of the time it's taking me to build things - I like to have stats for a "post mortem" once the project is done.
That's it for today, will post when there is more progress!
