That's the exciting way to get the game to work while reaching in through the coin door lol!
Yes if the motor is rotated the sequence will complete kicking the ball out.
Lemme think (I'm not near the machine now to confirm) there are a few methods where I can manually reset the game..
A game is played and ends. Game over is lit. Ball is in outhole. No tilt or anything unusual is noticeable. There are credits showing. The game is not set for free play.
The credit button is pushed and the startup sequence begins, all scores and play surface bonus's and lights reset correctly and then the game stops without kicking out the ball. At this point I can manually do two things reaching in through the door and get a restart.
1)If I give the top disk on the motor a push the motor will take over and continue another rotation, kicks the ball out and motor stops at it's correct position. And the game will play to its logical end.
2) I manually push in the AX relay, but not hold it, the motor will run and stop, I believe a third of a rotation, then if the credit button is pushed at that point, the game will reset and complete with the ball being kicked out to the shooter lane. Play on!
With either method the next game may or may not reset properly. It can be played multiple times without incident and also can be had to be manually reset multiple times. This usually causes a bad karma and i shut it down...until the next time!
