Working on my Gottlieb Groovy. When the motor is in its normal horizonal position and the replay button is depress, the motor runs one cycle. But when it is rotated to 90 degrees+ it runs continuously. I can handle this. But I can't find any reason for why. When the motor is at 90+ and I start to lower it, the motor stops.
I have checked for lose wires, tightened the switches, moved the main bundle -- no visual breaks, no tabs touching but haven't found any problems.
As this been seen before? Any suggestions? Cold solder joint? Shall I run the game with a toothpick holding it vertical?! Thanks in advance.
