Hello all-
First, thanks for any help that can be provided.
I'm a bit stumped on a 1976 Royal Flush bonus problem. First, when you knock down the drop targets, the correct white lights illuminate on the playfield. However, when the ball drains (in the outhole), the arrows don't work correctly - the bonus isn't properly scored. Sometimes it starts with the 3000 yellow arrow and then moves to 4000 and 5000, and they score correctly. But it skips the 1000 and 2000 yellow arrows. Sometimes it doesn't illuminate any of the yellow arrows. Other times, it works as one would anticipate.
I'm stumped. I pulled the AS relay (relay "I") and cleaned / rebuilt it. It's smooth as can be, and doesn't hang. There are two switches on the top of that AS relay that I *think* are adjusted correctly. What's a bit odd is that at one step point, one of the contacts moves some, but not the full travel distance. I'm not sure if that switch is supposed to be closed or open at that point.
I'm struggling to understand how it's supposed to work by reading the schematics. I'm more of a digital guy.
Hoping someone here knows how it's supposed to work, and maybe can provide some guidance.
Again, thanks in advance for any help that can be provided.
James
