I’m trying to get a Gottlieb two-player Quick Draw with a rough history back to life. I have the schematics and the manual. This is my first multi-player Gottlieb project. Almost all functions work by now, but I have frequently a problem with the ball and player advance. The problem happens both in single player and in two Player modes. When the ball lands in the out hole, any bonus correctly counts down, the ball then gets ejected into the shooter lane, on its way it triggers the trough switch. This sequence works.
If no bonus has been scored the machine advances reliably to the next ball / player. (Triggers the P relay which initiates both drop target reset and ball / player advance)
But if a bonus has been scored, the ball advances to the shooter lane very often without triggering a drop target resets AND a ball or player advance. Always both either work or don’t work.
I observed with an LED connected to the P relay coil, that in a “normal” case, the LED shows a solid maybe ½ second light, whereas in the failure case (no target reset and no ball/player advance) it shows just a very short flash or nothing. Probably not enough power to activate self-hold of P and initiate the reset / advance.
I have cleaned Motor switch 1C without improvement.
I suspect it could be a timing issue. Is it possible that the motor is still turning (with M1C open) when the trough switch is activated?
Anyone had that problem before or can think of the reason and cure for this?
