New! Dark mode!
(Topic ID: 156828)
Gottlieb Quick Draw/ Game over fault
By Raff
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Raff
#1 4 years ago
after the loosing the 5th ball in a game the machine shoots the ball out again instead of going into game over mode
#2 4 years ago
dont have that pin ,but i would look at player unit and coin unit if it has them
#4 4 years ago
Hi Raff
here http://www.ipdb.org/showpic.pl?id=1893&picno=25929 I see: Quick Draw has no Relay Bank near the player / behind the fuses -> the pin has the "AX-" and "BX-Interlock-Relays" (in the picture on the righthandside near the chimes). pinrepair has a nice video -> http://www.pinrepair.com/em/index.htm -> http://www.pinrepair.com/em/index3.htm#axrelayvideo -> in the video at 1:34 to 1:42 a fully working Interlock-Relay. In the video starting at 2:48 is the adjustment shown -> 3:40 to 4:10 a "not properly working AX-Relay -> then the adjustment ...
The AX-Relay is for "Resetting" - the BX-Relay is the "Last-Ball-Relay" telling the brain of the pin "When this ball is played -> You brain, You shall move to Game-Over". And if this relay does not actuate: No Game-Over.
Start a new game -> look at the AX-Relay -> see the movement -> play the balls -> when the secondlast ball is played and -> Outhole -> Shooter alley -> the LAST-Ball appears: the Player-Unit beeing stepped reaches "last-position (in this game)" and the BX-Relay should actuate.
Does Your BX-Relay actuate ? Greetings Rolf
#5 4 years ago
I have been working on a 'Fast Draw' machine over the past 2-3 months and had the same problem. Turned out to be a set of contacts the 'AX' relay.
As Rolf has suggested, the' AX' looks to be your issue.
#6 4 years ago
This problem comes and goes , just watched the video I will have a look at the ax relay anyway thanks to rolf and oldpins ,
& dr of style helping out
900 (Firm)
Ronkonkoma, NY
$ 4.49
Professor Pinball
$ 7,500.00
$ 9,000.00
Great American Pinball
$ 99.99
$ 5.00
Docent Electronics
COINTAKER.COM
Filament Printing
$ 40.00
Arcade Arts
$ 7,599.00
Operation Pinball
$ 22.50
Flashinstinct
$ 180.00
PinWorlds
$ 44.95
PinBoss Mods
$ 4.00
$ 999.00
$ 18.95
Operation Pinball
$ 29.95
Apparel - Unisex
The GameRoom Store
