(Topic ID: 271911)
Gottlieb Pro Football issue with resetting Football
By Spider3582
13 days ago
  • 9 posts
  • 2 Pinsiders participating
  • Latest reply 11 days ago by Spider3582
    #1 13 days ago
    After scoring a touchdown what tells the Football to reset on the first position(10yard line)? my game stays on the 10th football (touchdown) The AS relay is good ,no binding, clean, 2 switches work ,and I checked the switches on relays G, and BB. Any help would be appreciated.
    #2 13 days ago
    If the Advance Unit (I) doesn't reset to zero after scoring a touchdown, Inspect and diagnose this circuit with Alligator clip jumper wires
    http://www.planetimming.com/Pinball/troubleshooting/EM%20Troubleshooting.pdf
    http://www.pinrepair.com/em/index3.htm#features
    #3 13 days ago
    Thanks HowardR, I checked all the switches on relay G and BB but that will tell me if there’s a short. I was hoping someone knew what relay tells the advance unit to reset to -0-( ten yard line) but I will try that when I get home from work.
    #4 13 days ago
    Quoted from Spider3582:
    It's not a single relay and it's not whole relays:
    1. The Motor 1A switch provides multiple pulses
    2. A switch on the G relay activates the reset to 0 circuit
    3. The zero position switch on the I relay tells the circuit when the I relay has made it around to 0
    #5 13 days ago
    The I relay switches are good so if I check the 1A Motor switch and the switches on the G relay I should get it?
    #6 13 days ago
    Probably. If not, did you read the links I posted?
    #7 11 days ago
    Yes I did . I found the rely “B” and the switch. It works with the alligator clip but not with the switches. I think I have a broken switch inside the stack. Thanks for your help
    #8 11 days ago
    For a switch to work 3 things are necessary:
    1) When open, there should be a small space between the contact points (duh)
    2) When closing, the long blade's contact point should push the short blade's contact point enough to move the short blade
    3) The contact points should be clean, which they usually will be if #2 is happening
    #9 11 days ago
    This is a N/C switch that works with the clip on the prongs ( on top) but doesn’t work without it
    $ 36.99
    $ 19.99
    Apparel - Unisex
    Pinball Wheezer
    $ 59.00
    Full Tilt Pinball LEDs
    $ 90.00
    Lighting - Under Cabinet
    Creo Pinball
    $ 24.00
    PinWorlds
    $ 249.99
    Id Rather Play Pinball
    $ 34.99
    Cleaner
    Pinball Pro
    $ 154.00
    $ 5.00
    $ 295.00
    The Art of Pinball
    $ 9.99
    $ 79.00
    $ 69.99
    $ 54.99
    $ 11.00
    Third Coast Pinball
    $ 79.00
    Arcade Upkeep
    $ 7.00
    $ 9.99
