I've been having issues with this pin and most frustrating is I spent 2 weeks getting most of the electrical working and I disassemble to clean/touch up then reassemble and whole new electrical problems. Now that i'm thinking about it, the play field was still attached as i was scrubbing away the dirt and mess and remember having to hold the bottom cabinet so it didn't slide off the table. Definitely moved some switches and caused these new problems. at least the playfield looks better.
I've been having issues with the AX relay but Im getting close to having it all working except the pop bumpers. When I connect the right switch the pop bumper stays down and doesn't pop up. I have 2 (left and right) when i connect the left switch it makes the right bumper go down (and stay down).
I'm also having issues with start up sequence. Normally, I press start: 1 player (player 1 individual light is on and player 1 score reel lights is on), press again 2 player (only player 2 individual light goes on) and so on but the lights for player 1 score reels stays on. Now, every time I hit start the score reel lights go to the next player?????.....If I manually hold down start relay all the reels reset. I can't figure out why the AX isn't keeping the Start relay engaged. I check the line with the AX coil, re cleaned the switches (light filing), and still no luck.
i also noticed tonight this reoccurring liquid substance between the switch contacts. When i bought the pin, i noticed all the relays looked covered in WD-40 and there was liquid substance between some of the contacts. Cleaned everything and didn't think anything else about it. However, the pin is sitting in my garage and it's summer so I guess there's still moisture dripping down from whatever the previous owner sprayed. I close the play field and put a small fan at the coin door. Hope it dries everything out cause I don't want to keep cleaning switches. This is my second pin, my first one was much easier and surprisingly cheaper.....Why did i get attached to the bonus ball action on this 300.
i don't know how you pronounce gottlieb but after this pin, gah-its-a-bitch
