So I have a Gottlieb Polo, got all 4 players to work, resets, can play all 4 players to 5 ball/game over. Everything scores on PF. Vari-Target will score and move backwards. But the Vari target will not reset...unless I manually trigger the Z relay which controls reset. I checked all the motor switches and they have connection, no loose wires to the Z relay. Set on reset vari on each ball. The coil tests 33 ohms which is in range with another coil of the same type. I believe 24v is flowing to the coil. Gotta be a bad coil right? Anything I might have missed?
added the fair use relevant parts of schematics
