The obsession continues…
I just picked up a Gottlieb Playball.
I have two issues that I guess are related to each other that I could use some help.
1> Upon activating the replay button, with the ball sitting in the plunger trough(?) the ball count will go 1, 2, 3, 4, 5 (ball count unit 1-5 rivets) and then game over.
Now, if I activate the replay button but briefly touch the contacts in the plunger trough the game will go right to ball 1 and I can play after hitting the right flipper.
I seems as long as the ball in sitting in the trough the game will only cycle and go to game over.
2>The other related problem is the ball will not eject when I hit the right flipper button.
I cleaned the contacts under the apron but still no luck, I have to manually put the ball on the playfield.
I tried testing the coil that ejects the ball but my multimeter had crazy readings all over the place.
I also have the schematic but I’m still a bit of a novice.
Before I try anything else and risk making more problems for myself I figured to just ask for advice on how to fix it.
Thank you all for your help.
