Hi folks. I was cleaning the score reels on my Pioneer. I successfully completed six of the eight reels. After washing and re-assembling the second to last reel (the first player tens reel) my machine lit up when I turned it on, but then would not start the game and the Tilt light came on. It sounded as if the machine was beginning the start up sequence, but, no reels began to reset and Tilt immediately lit. I have taken the score reel apart and re-assembled it a number of times. I've checked connections and I cannot see anything I might have damaged/disconnected. I'd appreciate knowing if anyone else has had this problem, and where I should start. Thanks.
Edit: Okay, whatever I did wrong with the score reel caused a fuse to blow. It is marked as a 25 volt 15 amp fuse. So I have some additional digging to do. I'll grab some fuses and see if they keep blowing. Let me know if I should post a new thread. I'm brand new and just learning the protocols, so I appreciate your patience.
