These are the items which will cause the score motor to rotate.
D: 500 Point & Add Bonus Relay
E: Bonus Unit Score Relay
G: Hole Relay
Q: Game Over Relay
P: Add Player Unit Relay
S: Start Relay
W: 2nd Chute Relay
AX: Reset Control Relay
Motor 1C: Score motor Home switch
Here is a pic of my Spirit of 76 board. I suspect it may be similar to your Pioneer.
I'd suggest starting your machine and let the score motor run as it does, then locate which of these relay(s) are energized.
The score motor home switch is #1C. In my photo, it is the switch stack which is in the 6 o'clock position, the one which rides on the top disc cam itself. I am assuming the Pioneer will be the same but I am not sure of the motor switch assignments.
