I'm having a unique problem with the scoring on the two hole kickers. At the top of the playfield are two hole kickers that offer 500 and 5000 points when lit. The alternating relay controls these for scoring. When lit, both holes will correctly score 5000 points. But when not lit, they should score 500 points, any they do not. The left hole kicker will consistently score 4500, and the right will score 3500 points. All other targets score correctly as well as the drop targets. The WOW does score correctly and it does rotate through the drop targets correctly.
I think it is a timing issue. I've checked all of the score motor switch dogs and they are all positioned correctly. Your thoughts?
