Does anyone have this game, I need a picture of the score motors rotating disk.
Long story short, a very well seasoned EM tech and myself was trying to figure out why the 50, 100, and 150 lights were not alternating, they were stuck on 150 and would only light the other two(briefly) when the score motor turned a full rotation(these switches are located on the score motor). After we played with it a bit more, we realized that the position of the pins were out of whack when the motor found home. We looked at the shaft 'key' and the set screw on the keyed shaft was tight and looked aligned correctly. Our total assumption is, we decided the rotating disk is the incorrect one for this game. Maybe someone took a spare they had and tried to replace it. This was supported by a weird 'home made' pin, basically a screw, someone put on the rotating disk. We thought maybe the original broke off and this was a "fix" or the original was lost during an earlier repair and they tried to make do with this one. Pic of mine is included and this is where the motor stops in the home position.
So in short, I am in need of a pic to verify this assumption. Ultimately, if this is the case, what are my options? I know finding a parted PB can be difficult. Can these be reproduced? Should I pray to the EM Gods?
