This problem has been a tough one to resolve. Here's what is happening:
Game boots fine just as it should. Coin it up and Start a game. Drop target banks start to reset as they should and then the MPU almost immediately resets before you can play a game.
Here's what I've done and/or checked:
1. Power supply is solid 5.2 volts. The PS connector has been repinned and header pins reflowed.
2. CPU to Driver board interconnect has been repinned
3. Checked resistance on all coils and they seem to be correct.
4. New cap in bottom transformer panel
5. New bridge rec installed for solenoids
6. Replace diodes on drop target bank coils
7. Power supply, driver board and cpu ground mods done
Not sure where to look next. Put game in test mode to test solenoids and after at least one or two coils pulse the CPU reboots. Usually right after the second drop target coil pulses.
Anyone got any ideas?!?!
Dave
