(Topic ID: 161908)
Gottlieb Outer Space sometimes won't switch players
By n1teowl
7 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by GREG_O
#1 7 years ago
My Gottlieb Outer Space occasionally, about once per game, won't switch from player 1 to 2 (or vice versa). It advances to the next ball of the same player. The rest of the time it works fine. Any ideas? Thanks!
#2 7 years ago
I think that era has a reset bank towards the front of the bottom of the cabinet. Should have a PB relay (2nd player relay) that might have something going on with it...not sure how those work, later games had a player unit that would need cleaning. Someone with a schematic might be able to tell you what controls 2nd player relay.
#3 7 years ago
It might have something to do with the stepper unit in the head. It seems to be in a similar position when it skips players and doesn't happen again until it comes back around. I sanded all of the contact points and so that shouldn't be the problem. I'm going to try and take apart the stepper next to see what I can see on the back side.
#4 7 years ago
Also make sure the stacks are tight on the player unit, this can cause similar flakyness.
#5 7 years ago
Ive also had an issue where the throw of the plunger into the coil of the player unit was a little long causing it to sometimes jump two steps. This is fixed by loosening the mounts that hold the coil assy, in place, you'll see slots allowing up to 1/2 inch etc..
Manually activating the plunger and watching how much cog/gear it graps will give you an idea if this needs shortening.
Ken
#6 7 years ago
n!teowl
I agree. Sounds like the stepper unit. I cleaned the contacts with Barasso metal cleaner and it works great. Did you also clean up the spring loaded contacts? Check the wires connected to those contacts also. You can also try fine tuning the position. It might just be falling off the contact when it gets to that position. Good luck.
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-outer-space-sometimes-wont-switch-players and we tried optimising it for printing. Some page elements may have been deliberately hidden.
