(Topic ID: 312294)
Gottlieb Orbit Startup
By customelectronic
2 years ago
#1 2 years ago
Evening! I've been working on a Gottlieb Orbit, resurrected it from sitting idle for what I'm guessing 20 or more years and got it 99.9% working. I am stumped, or maybe this is normal- when I first power up the machine and press the replay button or insert a quarter, doesn't matter, the game successfully resets and ejects the ball, BUT then the player unit advances to "2nd ball". Plays normal the rest of the balls (no difference if 3 or 5.) Then if I hit the replay / insert quarter after game over it functions perfectly fine, starts player 1 / ball 1. Only happens on initial power on.... any thoughts / advice?
#2 2 years ago
Hi Mark, Welcome to pinside!!
Is the 1st Ball relay (ZB) on the relay bank getting tripped before you score any points?
#3 2 years ago
On a similar note, I wonder if the state of the ZB relay when starting the first game after power up is different than the state of the ZB relay when starting a game after finishing a previous game. I think the ZB relay should inhibit the Player Unit from advancing when the very first ball rolls over the Trough switch between the out hole and the shooter lane.
/Mark
#4 2 years ago
Thanks for the replies! I did watch the ZB relay- what I noticed is it was "open" until I scored points after the inital power up, then it closed. I didn't watch to see what happens after a game is played. I'll take a closer look at it and check the schematic to see what the contacts should be doing, maybe it's possible that when I cleaned it up the reset bar isn't adjusted quite right and it's resting just enough on it to hold something open or closed when it shouldn't be or simply the contacs just need adjusted?
#5 2 years ago
It was that simple, the reset bar was ever so slightly resting on some of the relays and it was causing that issue. All good now, thanks to you both, steered me in the right direction.
The Pinball Scientist
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-orbit-startup and we tried optimising it for printing. Some page elements may have been deliberately hidden.
