TL;DR By design, these twelve early ‘70s Gottlieb machines fire the ball return kicker twice per ball - Orbit, Outer Space, King Rock, King Kool, Jungle, Wild Life, Jack In The Box, Jumping Jack, Hot Shot, Big Shot, Magnotron and Duotron.
Background:
Several owners of early ‘70s Gottlieb multiplayer EMs have noted that their machines fire the ball return coil twice per ball in play. The first coil firing ejects the ball from the outhole towards the shooter lane as expected… but, as the ball activates the trough switch, the ball return coil fires again. Examination of the schematics for these particular machines revealed that they do not utilize the “standard” logic that Gottlieb had used both in earlier and later designs. This second ball return firing is a consequence of deviating from this standard logic. The motivation for this deviation is unknown, but they did switch back to the standard design in 1975 with Fast Draw.
Specifically, the “standard” Gottlieb design used independent O (Ball Return) and P (Add Player Unit) relays, each with their own dedicated hold and motor switches. Both O and P relays are independently activated (by the ball return and trough switches, respectively), activate the motor via their own motor switches, and remain activated throughout the motor cycle using their own dedicated hold switches (serving to deactivate the relays late in their motor cycles when their work is done). See attached schematic from Fast Draw.
However, ALL Gottlieb multi-player games (18 in total) between Orbit (1971-12) and Soccer (1975-03) do NOT have P motor and hold switches. Instead, P re-triggers O to turn the motor and taps into O’s hold circuit for its timely deactivation. This additional retriggering of O results in the second firing of the ball return coil. See attached Jungle schematic.
Other things to note:
- All games of this era with drop targets (8) use an additional P switch to inhibit a second drop target reset on the second O firing.
- Some games of this era (6) use an additional P switch to inhibit the second firing of the ball return coil when the ball is crossing the trough switch (Big Brave, Big Indian, Far Out, Out of Sight, Soccer, Super Soccer).
