Quoted from MarkG:That's the right first step. Which of those switches is closed? If you're not sure, you could block them with bits of paper.
/Mark
Mark,
I just checked every relay condition while its running. W, O, J, H, DB, & SB were all off and/or not latched. I then I tripped the Score Motor off with the Tilt. I held Motor 1C in and as I released it, it stopped. I held each relays W, O, J, H, DB, & SB in individually and the motor would run until I released them or unlatched them.
I can try to isolate each contact with post it paper but I would have thought I already had this covered by doing the above but it would certainly make it clear with no doubt that something foreign has entered the circuit somewhere.
I wish I had you and the guys on video chat. This would be entertaining.
Tom
