Once in a while, if the machine is rolling off a lot of points, it will change players before all points are tallied and the remainder will go on the next player. Can happen with either player. Ideas?
Having a problem uploading the schematic; it keeps giving me error messages. I will email it if you want-message me with info.
You'll need to check the schematic to see how the player relay or player unit switches between the players. Most likely, this would be a simple open/close relay coil that determines which player is activated. Check on the schematic to see what circuits send power to the player relay or player unit...
Quoted from currieddog:Once in a while, if the machine is rolling off a lot of points, it will change players before all points are tallied and the remainder will go on the next player. Can happen with either player. Ideas?
This involves a complicated circuit with multiple steps and delay relays.
Does this happen when it's giving 50 points?
Does this happen when it's awarding the bonus?
This page was printed from https://pinside.com/pinball/forum/topic/gottlieb-mayfair-occasional-score-problem-with-schematic and we tried optimising it for printing. Some page elements may have been deliberately hidden.
